Share
 Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?
Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?  Empty
PostSubject: Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?    Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?  EmptySat Jul 17, 2010 9:47 pm
A Good Read http://www.wellworthproducts.com/articles/phaseseparation.asp
I removed all the plugs (I think) for the cure the website is pushing to treat e-10 fuels.
I myself am using..............
Marine Formula STA-BIL the blue stuff. Big jug sells for about twenty bucks.
Phase Separation in Ethanol Blended Gasoline´s
Phase Separation in Gasoline’s containing Ethanol is now a major problem for all users of gasoline.
Whether you use gasoline as a fleet operator or for your family car, classic car, boat, personal water-craft, motorcycle, snowmobile, ATV, RV, lawnmower, weed-whacker, generator, or any of the thousands of other types of equipment that use gasoline engines; you are being affected by Ethanol in your fuel.
Phase Separation describes what happens to gasoline containing Ethanol when water is present. When gasoline containing even small amounts of Ethanol comes in contact with water, either liquid or in the form of humidity; the Ethanol will pick-up and absorb some or all of that water. When it reaches a saturation point the Ethanol and water will Phase Separate, actually coming out of solution and forming two or three distinct layers in the tank.
Phase Separation is also temperature dependent. For example, E-10 can hold approximately .05% water at 60°F. To better understand the amount of water that we are talking about, picture 1 gallon of E-10 at 60°F. This gallon will hold approximately 3.8 teaspoons of water. However if the temperature drops to 20°F it can only hold about 2.8 teaspoons of water. (See chart below)
We recently heard about a fleet where a fairly large number of vehicles were fueled from a single tank and about one-half the vehicles were stored inside and the other half were stored outside. After a night with a 30°F+ temperature drop, several of the vehicles stored outside developed problems with significant amounts of water found in the vehicle tanks. After checking the storage tank and finding no measurable water, they looked for other possible causes including sabotage. After looking at many possible causes we were consulted and we were able to describe the Phase Separation through temperature change scenario and determine that this was the most likely cause of the problems.
Phase Separation can happen in an underground or an aboveground storage tank, a vehicle tank, a boat tank, in any type of equipment tank, and even in the gas can in your garage.
When this happens, you can have serious and even catastrophic engine problems, without warning.
When this Phase Separation occurs you will have an upper layer of gasoline with a milky layer of Ethanol and Water below it, and then in many cases a third layer of just water at the bottom.
If this happens and you try to start the engine you can have one or more of the following problems. If your fuel tank pick-up tube is in the water layer, most likely the engine will fail to start. If the engine is running and suddenly draws water you can have damage from thermal shock or hydro-lock. If the pick-up tube draws the Ethanol-Water mixture or just Ethanol you can have problems where the engine will operate in an extreme lean condition, which can cause significant damage or even catastrophic failure. If the pick-up tube draws the gasoline, it will operate very poorly due to lower octane that is the result of no longer having the Ethanol in the fuel.
Gasoline containing Ethanol provides further challenges and dangers for marine operators (Boaters) and other users of seasonal equipment such as motorcycles, personal water-craft, snowmobiles, ATV’s, RV’s, yard maintenance, generators, and other equipment.
Ethanol is a strong, aggressive solvent and will cause problems with rubber hoses, o-rings, seals, and gaskets. These problems are worse during extended storage when significant deterioration will take place. Hoses will delaminate, o-rings will soften and break down, and fuel system components made from certain types of plastics will either soften or become hard and brittle, eventually failing. Fuel system components made from brass, copper, and aluminum will oxidize to the point of failure.
Two-Cycle engines have a special problem with Ethanol blended fuels. Two-Cycle engines function because the oil added to the fuel bonds to the engines metal surfaces and provides barrier lubrication to all the parts requiring lubrication. When Ethanol is added to the gasoline, it displaces the oil and forms a primary bond with the metal surfaces. This bond provides virtually no lubrication and can result in significantly increased wear and even catastrophic failure in a very short amount of time.
Gasohol, E-10, E-20, and E-85 are the terms that refer to gasoline containing Ethanol. For example the most common fuel available today is E10. E-10 is 10% Ethanol and 90% gasoline, while E-85 is 85% Ethanol and 15% gasoline (Note: E-85 is actually E-70 in the winter in cold weather (Northern Tier) states.
Ethanol has less energy (as measure in Btu’s – British Thermal Units) per gallon than does regular unleaded gasoline. This means that the more Ethanol found in fuel the worse your fuel economy will be. You use more gallons of fuel containing Ethanol to go fewer miles.
This poor fuel economy is made worse by other EPA and State requirements for fuels to change seasonally. Until very recently we have used what is known as “Conventional” gasoline (CVG) in the winter and “Reformulated gasoline (RFG) in the summer. The theory is that the lower volatility of RFG will reduce the formation of green house gases. However RFG has lower Btu’s per gallon. RFG together with Ethanol results in a significant mileage penalty. My own vehicle drops about 2 miles per gallon or about 9% when using RFG with Ethanol.
For many years the refining industry used a chemical called MTBE to meet the oxygenate requirements set forth by the EPA. Generally refiners used 15% MTBE and 85% gasoline. However MTBE has now been virtually eliminated in the US due to its carcinogenic compounds and the huge potential problems caused by its pollution of as much as 75% of the ground water in the US and Canada.
This has left Ethanol as the primary additive to meet Federal and State oxygenate mandates.
Further the federal government currently subsidizes Ethanol with a $.51 per gallon tax credit that goes to the refiners or blenders. With E-10 this provides those refiners and or blenders with a $.051 per gallon subsidy on every gallon of gasoline that they sell.
In many cases we have seen gasoline containing more than 10% Ethanol. We test regularly and have seen fuel containing 12%, 13%, and even 14% Ethanol while the pump shows only 10%. Increasing the amount of Ethanol increases the refiner/blenders subsidy and profit while further lowering your fuel economy.
One more concern with Ethanol and RFG or Ethanol and CVG is that Ethanol when mixed with water; they readily form Gums in the fuel system much quicker than gasoline without Ethanol. These Gums coat fuel system components including filters, carburetors, injectors, throttle plates; and will then form varnish and carbon deposits in the intake, on valves, and in the combustion chamber. These deposits can coat sensors and plug catalytic converters.
1. When Phase Separation occurs in fuel tank on a vehicle, boat or other piece of equipment, the tank should be completely drained. The tank should be refilled with good fuel and the fuel line purged prior to restarting the engine.
If you have fuel that has Phase Separated and you have either two or three layers you should arrange to have the tank pumped from the bottom to remove the one or two bottom layers containing the water and or the Ethanol/Water mix. (Note: you should check again with the paste before the technician leaves to be certain that all the Water and Water/Ethanol has been completely removed). You do not need to remove the gasoline. Treat with One-4 All™ at one gallon per one thousand gallons of tank capacity (one gallon minimum). Check with water finding paste after 24 hours. If no red or yellow present then add clean fuel to the tank to working capacity and then treat with OctiPlus™ at one gallon per fifteen hundred gallons of fuel.
View user profile https://www.facebook.com/venture72
PostSubject: Re: Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?    Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?  EmptySun Jul 18, 2010 5:08 pm
Thanks for the detailed post. Not sure I understand the fine points, but I will give it some serious thought. Gerry
PostSubject: Re: Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?    Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?  EmptySun Jul 18, 2010 9:06 pm
The main gist of it is instead of getting a layer of water at the bottom of the tank you get a layer of water then alcohol then gas on the top.
PostSubject: Re: Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?    Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?  EmptyTue Jun 21, 2011 12:37 pm
"Dry gas" to the rescue?,possibly?.
PostSubject: Re: Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?    Ethanol E10 Blended Fuels & Phase Separation ....... What's phase separation?  EmptyThu Jun 23, 2011 7:22 am
Trying to use only non-E gas if possible. Found a few stations in my area.
http://pure-gas.org/index.jsp?stateprov=WA
» 2011 Boys PHASE 1 Academy " 4 more spots available!"
» Citizen Eco Drive Moon Phase watch BU0011-63ZB Review
» New wireless headphone setup from phase technical
» Ethanol Challenged XXX
» Ethanol FREE North Carolina gas stations...
TW200 Forum :: General :: Other Bikes-
