 Couple questions Neutral Bulb/Cold Weather
3 posters
mrutkaus
Couple questions Neutral Bulb/Cold Weather Empty
PostSubject: Couple questions Neutral Bulb/Cold Weather   Couple questions Neutral Bulb/Cold Weather Empty1/4/2011, 1:58 pm
Well all of a sudden my Neutral light went out at 600 miles on my 2009! I was charging the battery and might have momentarily switched to high charge for 1/2 second.
Anybody know the number of the neutral light bulb?
AND...with a 45 deg F day here in VA I went for a ride and noticed it took a LOOOOONG time to warm up and needed the choke to run well, not like during the summer; is this fairly normal? Added some SeaFoam to the new Clarke Tanke.
I guess this is the old forum?
Mike
Wincheter, VA
PostSubject: Warm-up   Couple questions Neutral Bulb/Cold Weather Empty1/5/2011, 6:32 pm
This is not really the "old" forum, it is a forum started by a concerned "old forum" member (lets keep it going).... The bulb issue is going to be anybody's guess. Your 'warm-up' experience seems about par for your weather conditions. You may be able to do a couple of simple adjustments to shorten the warm-up time. Check this, and the other forum for "carb adjustments" "jetting" or "raise needle" good luck and come back to keep this site active.............. Gerry
mrutkaus
PostSubject: Re: Couple questions Neutral Bulb/Cold Weather   Couple questions Neutral Bulb/Cold Weather Empty1/5/2011, 10:57 pm
Hey very good to hear from you!
I did search this forum and found https://www.superbrightleds.com/cgi-bin/store/commerce.cgi
where the BA9s type bulbs seem to be the ones for the 'dashboard.'
Thanks for the info. Yes some little carb twiddling is in order.
I was complaining at 40 Deg F, I remember people riding at much lower temperatures, I wonder what they did? Porr little motor needs a coat!
Mike
PostSubject: Re: Couple questions Neutral Bulb/Cold Weather   Couple questions Neutral Bulb/Cold Weather Empty1/11/2011, 5:26 pm
I'm a little late to reply as you seem to have found the info you needed, but will add what I found for some background or alternate source information.
The instrument bulb you need is Yamaha PN# 123-83516-21. I googled the PN# and found this place to order them if you don't or can't get to a dealership and want to order online: http://www.boats.net/parts/search/Yamaha/Motorcycle/2003/TW200RC%20-%20TW200/METER/parts.html
They listed the bulb as MSRP of $2.59 and their price as $1.97. Sorry I wasn't able to help before you found the info on your own.
On another note, I started my TW yesterday. About 20 degrees out. Started right up with full choke on. Pushed to the halfway point after about 30 seconds. Stayed there for about 3-4 minutes before I could push the choke all the way in.
P.S. For your carb care, for what its worth. From info I learned on the other TW forum, I put in Mystery Marvel Oil in the gas (doesn't take much per the instructions), back in November. Ever since then, every time I try to start the TW, it fires right up. Even after sitting for a few weeks. I suspect Seafoam does a very similar thing, though I have not used this product. Both products are suppose to stabilize fuel and help keep carb/fuel system clean. I don't know about Seafoam, but MMO can also be added to the engine oil. I did. No ill effects so far.
mrutkaus
PostSubject: Re: Couple questions Neutral Bulb/Cold Weather   Couple questions Neutral Bulb/Cold Weather Empty1/12/2011, 2:22 am
20 deg, that's encouraging. Thanks for the bulb info. I do use seafoam, but come to think of it, just had put the Clarke tank on about 4 months ago and may not have added any.
Mike
