 carb swap?? is it worth it? will it work?
2 posters
bwiygul
carb swap?? is it worth it? will it work? Empty
PostSubject: carb swap?? is it worth it? will it work?   carb swap?? is it worth it? will it work? Empty5/17/2011, 10:50 pm
Hey everybody new tw owner. got an 87 but having some carb problems...first things first though. before i start messing with the stock mikuni is it possible to just put a TK on? are they plug and play? thanks in advance.
PostSubject: Re: carb swap?? is it worth it? will it work?   carb swap?? is it worth it? will it work? Empty5/20/2011, 7:41 pm
I have not done what you are 'considering'. I am 62 and have wrenched more than 'a bit'. In my opinion, what you ask is likely possible and as well very do-able. "plug-and-play", very unlikely. In my experience, stuff like this takes some (perhaps more than 'some') minor/major tweaking. If you can, try to play or replace with what you currently have. Good luck. Gerry
» 91 to 05 engine swap....question about the wiring
» Carb and muffler
» Carb help needed
» TK carb Main jet, needle spacing change
» Tips on how your Private Messages work - PM's
