 swingarm zerks
PostSubject: swingarm zerks   Sat Jun 25, 2011 3:20 pm
Decided to add some grease to the swingarm via the zerks.Used some moly & graphite grease...only received a couple of "pumps'" before the handle stopped moving...wouldn't take anymore I suppose.On my prior bike...xr650l...you knew when to stop adding grease when grease came out the end caps?.I hope you can't overfill these tw swingarms?.
PostSubject: Re: swingarm zerks   Sun Jun 26, 2011 5:52 am
Had my swing arm off this past winter when I was repainting the TW (2005). When I took the swingarm off I noticed how dry it was. When I put it back on, like you, it didn't take too many pumps before I met resistance and didn't want to over-do-it. One thing I did prior to reassembly of the swingarm, I pre-lubed the the swingarm shaft bolt with grease. I used regular grease though, nothing special.
PostSubject: Re: swingarm zerks   Sun Jun 26, 2011 4:49 pm
Aye,aye admiral!!!!.
swingarm zerks
» dirtsurfer
» What are people using for front rims?
» adding grease fitting to the rear hubs
» Adding grease fittings to extend the life of your transaxle?
