 Rear Disc Conversion
Japblock
PostSubject: Rear Disc Conversion   Thu Sep 15, 2011 10:43 am
Converted from a drum to a disc using a Yamaha YZF-R6 Rear Wheel!
What do you guys think?
PostSubject: Re: Rear Disc Conversion   Sat Sep 17, 2011 9:24 pm
Looks like a mod with lots of promise. How doable do you think it would be with the stock rear wheel? Thanks for the idea. Gerry
Japblock
PostSubject: Re: Rear Disc Conversion   Wed Oct 05, 2011 9:00 am
Anything is possible!!!
You would have to take the stock wheel apart and customize the hub to take a disc or something like that at least
PostSubject: Re: Rear Disc Conversion   Wed Nov 14, 2012 5:58 pm
Japblock.......WOW,I really like that. A dude could make some $$$ if they were to figure out what would be needed to make this into a "kit' conversion thingy!.And also something for the front....this would be for a person who ONLY rode the street.Now, of course,it would be nice for the 50/50 crowd to have so they could switch back and forth for obvious reasons!....GOOD work.
SW200
SW200
PostSubject: Re: Rear Disc Conversion   Thu May 30, 2013 11:43 am
What wheel is that? From a CBR or something? I'd be interested in knowing which wheels could swap out and thereby allow the disc brake as shown. Then with two different disc-brake capable wheels you could swap tires between on and off road by swapping the whole wheel. Much faster and easier than changing tires!
» SuperATV Disc Brake Conversion
» Rhino Rear Brake AWFUL Noise -- Normal??
» grease to oil conversion?
» Rear Sway Bar Delete on RZR-S
» TMJ's Craftsman LT1000 Conversion Thread
