ROUGH RIDER
Posts : 2 Points : 6 Reputation : 0 Join date : 2012-09-04
| Subject: CANNED AIR FOR FLATS 9/4/2012, 3:27 pm | |
| I dread the possibility of a flat. What canned air flat fixer works? | |
Admiral Moderator
Posts : 116 Points : 201 Reputation : 1 Join date : 2010-06-08 Age : 63 Location : Sand Hollow, Idaho
| Subject: Re: CANNED AIR FOR FLATS 9/6/2012, 12:30 pm | |
| My recommendation would be Ride-on tire sealant as being the best product. You put it in the tires prior to riding rather than when you experience a flat. Ride-on also helps balance the tires. Here's a link: http://www.ride-on.com/
Some riders also use Green Slime, and is applied in the tires prior to a flat, similiar to Ride-On. I've not used Green Slime, but I hear is corrode the inards of the tire/rim/inner-tube though.
I suppose a can of fix-a-flat can work, but I've never had any luck with this type of product other than for a very small leak. | |
