 CLUNK !!!
ebikerman
PostSubject: CLUNK !!!   Fri Oct 19, 2012 10:35 pm
My TW200 has a clunking sound when hitting hard bumps. Sound seems to come from the headlight area, but cannot be sure. Sounds like what you would hear from a street bike with something bouncing in the headlight shell. Thanks
PostSubject: Re: CLUNK !!!   Tue Oct 23, 2012 6:24 pm
Yup, most of us have it, and to date no one have come up with a definitive answer. I now run a different fork completely and no longer have that 'clunk'. But as yet, no one has suggested the "sound" suggests or is associated with a problem. Gerry
PostSubject: Re: CLUNK !!!   Fri Nov 09, 2012 6:01 pm
Gizmo is correct on stuff. But, if you feel the need,possibly check the steering head bearing(s).....make sure all is within torque spec.?.
PostSubject: Re: CLUNK !!!   Sun Jul 28, 2013 9:49 am
My '97 was a klunker and my '07 is too, I know of two other TW's that have the klunk as well.
Only a fool would attempt it, and God help me, I am that fool!
PostSubject: Re: CLUNK !!!   Wed Jul 31, 2013 7:21 pm
Knock on wood, I don't yet have a clunk. But I installed different innards in my fork tubes.
PostSubject: Re: CLUNK !!!   Thu Aug 01, 2013 4:39 am
You may have found the secret, on mine the clunk goes away after a few miles, wierd.
PostSubject: Re: CLUNK !!!   Fri Sep 05, 2014 6:00 pm
Mine just started clunking after a 30 mile ride :(
PostSubject: Re: CLUNK !!!   Fri Sep 05, 2014 6:09 pm
The clunk comes and goes, we'll never find out what it is bang
CLUNK !!!
