Hodakaguy Admin
Posts : 55 Points : 34 Reputation : 0 Join date : 2008-12-19 Location : Eastern WA State
| Subject: Re: Spot transmitter 12/28/2008, 8:00 am | |
| Here's a long running thread on the SPOT over at ADVRider: http://www.advrider.com/forums/showthread.php?t=282391
Hodakaguy | |
Peruano
Posts : 14 Points : 2 Reputation : 0 Join date : 2008-12-21 Location : Sunny New Mexico
| Subject: rei bargain 12/31/2008, 5:13 pm | |
| Unless I heard my friend wrong, he bought a unit for $80 at REI with the first year of service free. Its worth checking out at that price. tom | |
| Subject: Spot tracking 1/2/2010, 4:10 pm | |
| Well, a number of months ago I decided to pay for the 'constant tracking' mode. My thought is, for the few extra dollars, I do not have to remember to push a button and hope that I am in an area that will allow my signal to go through. Now, every ten minutes, the unit automatically sends my location to my 'Loved ones' without me having to do anything. I am inclined to say, for me, this is well worth the modest increase in price. Gerry | |
| Subject: Self leveling Spot 3/22/2010, 7:25 am | |
| For the last couple of years now, I have used the Spot unit on every ride. In my opinion, the "Tracking" option is a 'must have'. Recently the thought came to me, that should I fall, and am unable to get back up, the Spot unit mounted on my handlebar may end up oriented in such a way as to prevent any further transmissions from getting through. I decided to work on a mount that would always allow the Spot's antenna to point skyward regardless of the bikes position. The Wife actually came up with this idea, so I ran with it. It is simply, a small camera case, I cut the webbed belt loop and used a soldering iron to melt a couple of holes. I then frabricate a pivot point using 1/4" fiberglass rod and a heavy duty 6 gauge wire terminal. The pivot is mounted as to point forward and be oriented horizontal to the ground. The camera case w/Spot hangs, and rotates freely from this rod. I have capped the end of the rod with grommet so the unit will not slide forward and off the rod. Seems to work fine. Gerry | |
JVT
Posts : 2 Points : 2 Reputation : 0 Join date : 2010-07-25 Age : 72 Location : Enumclaw , Washington
| Subject: spot 7/25/2010, 7:12 am | |
| I am interested in hearing from anyone who has used Both new and old version of spot. After all.You really can't compaire them if you haven't done both. Is the new any faster to send out signals? Jim | |
R80rt Moderator
Posts : 113 Points : 175 Reputation : 0 Join date : 2011-09-21 Age : 67 Location : Hills of Arkansas
| Subject: Re: Spot transmitter 4/26/2014, 8:53 am | |
| This is my first riding season with the SPOT, the tracking sure eases my wife's mind when I disappear into the wastelands. | |
| Subject: Re: Spot transmitter | |
